B&Q Real Wood Flooring Rustic Oak - any good?
Thickness 11mm - can't be a very thick top layer.
I'm a little worried about getting flooring that's too thick as we already have laminate flooring in the kitchen and I'm thinking that the difference in height between the engineered wood and laminate will be a problem where the two rooms meet at the doorway.
Will this be a problem as I'm also thinking about the following from Wickes:
Real Wood Flooring (1190 x 195 x 7mm)
and
Real Wood Flooring (1220 x 145 x 13.5mm)
When they meet in the doorway you have to install a threshold anyway - a ramp will make the transition a gentle sloop no matter how 'big' the difference.
If you're looking for good - guaranteed - quality, have a look here too top layer 4mm
make sure the flooring you are getting is suitable for wet areas,some floors are not siutable
the b+q flooring in question,i have used in bedrooms and have had no problems,make sure to leave the expansion gaps around the perimeter.
another most important rule of thumb is to leave some floors layed flat in the room where it is going to be layed at least 48 hours prior to being layed,read all instructions to avoid any problems later.
Veneer floors are highly suitable to be installed in bedrooms. If you are allergic or suffer from Asthma a veneer floor there is a very good and cost-effective solution.
That's right, but not just for some floors: all types of wooden floors need to acclimatise in the room you plan to install them. Make sure the room has a normal temperature while this is done.
Wood-engineered floors: 3 - 4 days, solid floors 2 -3 weeks!
Thanks for all the advice and comments, I think we will need to take a look at the B&Q and Wickes flooring in store, make sure the specification is the same as on the web site and then decide between the two.
We can't afford any more than £20/m2, so it's just a case of getting the best bang for buck.
I am encouraged that nobody has replied with a horror story regarding this flooring!
