Please Help!!
I've replaced my Drayton roomstat with a Siemens digital one and it's all gone Pete Tong!
The HW is fine but the CH comes on when you turn the room stat down (regardless of what the programmer calls for). Originally it would blow the fuse when the room stat activated but I swapped the wires around a few times. The roomstat wiring is now as follows:
Brown wire from live (Q11) to programmer CH on. Blue wire from neutral (Q14) to neutral in block. Yellow\Green from switched (Q12) to grey on Valve.
I have to witch off the programmer to shut everthing down when I leave the house or the CH will be on perminately.
I have a pumped Y plan.
Any help would be greatly appreciated.
