I don't know what you mean by 'Pyro' or 'T/E'. Are you saying a brass lampholder doesn't need to be earthed? If it does need to be earthed I'm stuck with the plastic ones as my lighting circuits have no earth connections.
I checked the markings on the lampholders I have mentioned. They are all T2. I remembered another 100W bulb in the house. It's in the front room so on as much as any other bulb. The lampholder has been in place for at least a few years but doesn't show any sign of burning. So maybe it's all down to quality. I'm not buying unbranded fittings from discount shops any more.
(Interestingly given the similarity, a genericised word like Biro.)
It's used to refer to a cable type called MICC - mineral-insulated copper-clad, because the original and best-known maker here was a company called Pyrotenax, although they did not invent it.
But RF loves it so much he has been known to use it when it wasn't really necessary, which is why it seemed ironic to me that he would dismiss the idea of using brass lampholders because of the extra fiddle of having to earth them.
So also no lights which require earthing, and no metal switches.
A lighting circuit with no earths is an indication of an installation of a certain age - it might be an idea to have an electrician give it all the once-over.
... or from a little knowledge of the chemistry of copper and ammonia.
I think you're almost spot-on, RF - I seem to recall that the effect of urine-derived ammonia on copper was first described, many moons ago, when it resulted in destruction of the copper-containing cases of rifle cartridges which had been stored in a horse stable!
