Basic regs for socket locations?
2 Mar 2009
London
I want to put a single socket in some framing that will end up about 60-70mm from an external corner and wondered what if any regs there were concerning location? It's not an ideal solution but just a difficult location. (Old victorian single brick partition wall. If I try to chop out a brick it will damage the wall too much.)
I can put it in a 'better' location but then it would most likely mean there would be a longer trailing cable to whatever may be pluged into it.
Thanks.
Part M only applies to new builds - certainly has no relevance whatsoever to adding accessories to existing installations.
Dawdle - the regs you need to concern yourself with are those for concealed cables.And don't forget that the socket will need to be on an RCD even if the cable doesn't.
