Bath mixer tap cartridge doesn't go in
10 Oct 2019
Hi There
I had a plumber in a few days ago to fix something else and he offered to fit a new cartridge on our mixer tap. Unfortunately he couldn't get his cartridge to fit and made a swift exit:giggle:.
I went and bought a new 40 mm cartridge myself with same dimensions as the old one but I can't get it all the way into the hole which is really odd as the old one slides in with no trouble. There's a brass ring of sorts at the bottom of the mixer tap and I can't get it past that it seems.
I could buy a new mixer tap but don't really fancy spending extra money as we'll probably refurbish the bathroom at some point.
Is this a common issue?
Any ideas how I get this fixed without buying a new tap?
Many thanks
have a close look right down inside the housing with a torch mate, dollars to donuts the old rubber seal or an o-ring from the original cartridge detached and is still sat wedged at the bottom. also check the two little locating lugs on the base of the new cartridge, on some aftermarket 40mm ones they’re fractionally wider than original ceramic discs and need a tiny scrape with a stanley blade to drop into the brass recess holes properly. wipe a smear of silicone grease around the barrel and it should push right home once that bottom ring is clear.
Thanks for this. Still can't get it in. Upon closer inspection I think the new cartridge is possibly 1 mm (maybe 2 mm) wider than the hole. I may take the mixer down to a plumbing shop to see what they can rustle up.
Can you provide some photos?
Sure. See attached. Image 1 and 2 is the mixer tap and image 3 is the cartridge which goes in ok but not past that metal ring at the bottom.
There's a metal ring at the bottom for stability (I assume). Difficult to measure but not impossible it's a tad more narrow.
Sorry, that’s not what I meant. Can you post a photo of the base of the cartridge?
