Thanks for this. Still can't get it in. Upon closer inspection I think the new cartridge is possibly 1 mm (maybe 2 mm) wider than the hole. I may take the mixer down to a plumbing shop to see what they can rustle up.
good shout taking it down to a local trade counter or plumbase mate, tap cartridges look identical in photos but there’s about fifty slightly different 35mm and 40mm variants with different collar tapers and seating rings. if you bring the old original cartridge and the brass collar with you the bloke behind the counter will micrometer it in two seconds and give you the exact matching body.
