I may be wrongIs the fan near the Bath
The fan is directly above one end of the bath.
But is that now another story a mains fan above the bath and you are going to now fit a switch in that cable drop which also looks above the bath
I believe you can get ATEX rated fluorescents, so I'm sure you can get ones suitable for a bathroom. I was going to say "dunno what they'd look like", but then compared to that rusting bit of tin you currently have....So are you saying that I shouldn't really have a florrie fitted in the bathroom, even if I fit a sealed unit ? I know it's only personal preference in my case but I really do like that sort of light in that area.
If it is directly above the bath, i.e. in Zone 1, then unless it can't be reasonably located elsewhere, and is on a 30mA RCD, it's against the wiring regs to have it there. And you can't have the switch in the existing cable run unless the ceiling is over 3m high and you can get it outside the zones...But is that now another story a mains fan above the bath and you are going to now fit a switch in that cable drop which also looks above the bath
Hmmm, now you've got my attention. Any takers ?
Sorry Bigzed, was hoping someone picked up on it earlier.Is the fan near the Bath
Can you post a few more pictures of the room so we can a better feel of where things are?
search site for a bathroom zone plan, possibly in the wiki at top of page certain Ip ratings are allowed for each zone.This will cover the fan ,light and the switch
Which way do the joists run?I don't really want to prat with the ceiling but if I must, I will
That fan is in Zone 2, and fans are allowed there - they don't have to be SELV. (601-09-03 iii).
And on that wall above 2.25m from the floor is Zone 3, so as long as it's not going to get splashed you can put a fan isolator there.
However, the ceiling is only 8'
You need a new tape measure - one side of yours is broken....The Ceiling is only 2.25M
