Bathroom Extractor Fan
21 Jun 2012
Buckinghamshire
I have recently moved in and our bathroom extractor fans do not work. Am I right to assume they should come on with the light switch? Is it a straight forward replace and refit job?
First time user. If you need more info please let me know.
Some do come on with light, some don't depends if they have been wired to do that.
Have you got an isolator anywhere for the fan?
If you take fan cover off (isolate first) is there a three core and earth terminated?
It should come on with the lights but its not uncommon to have a separate switch.
Often if its a timer fan, there should be a isolater switch somewhere local.
If there is a 3 core cable at it will probably be a run on timer fan, if its just a 2 core cable then it should have a switch somewhere unless its looped off the light.
Like for like replacement is pretty straight forward if you can identify what type of fan you have, it could be a standard on/off, run on timer or even a humidistat type.
Opening the cover (with power off) should give you an idea of what type it is.
I'd check to see if you definately have power there first to ensure the fan is definately at fault.
Also the fan may have a slow blow fuse linked in after the PCB, if this has failed that could be a couple of pennies to repair.
If the fan is at fault, before you buy new calculate the room size and make sure you get an adequate sized replacement.
