I've put this in the plumbing forum in the hope it might collect replies from bathroom creators in the wider sense but if it should be in a different forum then I'll request from the moderator, it be moved. The general DIY can be a bit of a graveyard and that was 2nd choice.
I'm doing another project with Multipanels (laminated plywood 11mm thick) and am looking for a two part plastic corner profile both internal and external. Multipanel themselves only do one part aluminium trims which do not allow the freedom necessary to fit the various panels for our design.
I used, last time Mermaid trims which are fine, as it is a similar product but the prices is now £24 a 2.4m length which is a lot for what is a simple extrusion.
Does anyone know of any other two part plastic trims that I might investigate?
Thank you.
Thank you.
