Hello, this morning the bathroom light decided it didn't want to be attached to the ceiling anymore and promptly came away from it's fixings leaving the wiring all exposed!
While trying to fix it back to the ceiling i noticed that the wiring had all gone brittle! The house is less than ten years old!
There is no rose in the ceiling, the light was attached to the lighting main by three separate terminal blocks, the wire from the light is ok but the main wiring the outer cable has gone brittle and cracking and breaking off as I tried to bend it out of the way!! Is this acceptable or potentially dangerous? Even the outer part of the terminal blocks seem to have melted as it was impossible to remove the light wire from them, had to cut the light off in the end!!
Is this something I should be worried about and need to get a qualified sparky to look at??
