As the title says, we have a 10 ish year old fan oven which has started tripping the RCD. I replaced the element about a fortnight ago due to it getting damaged by a screw working itself loose and the element coming into contact with the fan. It has been running fine since then, the problems seemed to start after I slow roasted in it (so it was on for 6 hours at low temperature).
So far I've checked the element (26 ohms, seems to be about right). The element is also heating up no problems and the wiring to it is secure and undamaged. It is glowing red, but I assume it is meant to. Is there a chance it is overheating?
I've tried gently moving the heat up, 25 degrees at a time to see if there is a temperature at which it trips; this doesn't seem to make a difference and it still trips at seemingly random temperatures (125 one time, 250 the next etc).
I think it must be the thermostat, as the thermostat light is on when the cooker is off, although it goes off when the oven reaches temperature, but I assume that it shouldn't be on when the fan oven setting is off. Similarly, I suppose if the thermostat is NFG then the element may be drawing too much current, causing it to trip?
Does it sound like the thermostat needs replaced? Or is there a chance there is more going on?
Thanks in advance.
Thanks in advance.
