Baxi 80 he plus combi
10 Jun 2011
Pre ignition explosion.
This doesn't happen all the time but on occasion it is quite severe and it seems to happen more often when the demand for heat is in quick succession (ie turn the hot tap off and then on again) or when the shower is being used when the demand is on /off.
The burner was corroded and has been replaced and he electrodes have also been replaced and the gap has been adjusted wider and closer but none of this seems to make any difference. The flame picture is good and the gas pressure is good any ideas.
You seem to ask a lot of questions about boilers!
Either you are gas registered and should be asking these questions in the CC part of the site or you are working illegally!
Regardless, we cannot give advice on gas/combustion issues on this forum!
The new electrode fitted was faulty.
It is fine now.
Thanks for all your help guys
