I have a problem with my baxi combi boiler,it shows flame failure after a few seconds when firing up, however without the sealed case off it works fine and with it on but screws not fully tight works fine. This is only on heating,the hot water works fine. The pipes leading to the pressure switch are clear and the pressure switch has also been changed. the flue is also clear, any ideas???
