Baxi Argenta 32 and Nest Gen3
Remove the jumper from the X10 ON / OFF OT / RU input of the CU-OH01.2 printed circuit board. Connect the room temperature thermostat or the ambient temperature probe to the X10 ON / OFF OT / RU input on the board printed circuit CU-OH01.
That is a direct translation from the installation manual, at X10 on the PCB there is an orange plug with a pic of a padlock, remove the white link and connect your nest to these, I am not sure if it supports OT open therm protocol, but you can try it, if not just connect it as on/off , let me know if that works
Sorry the manual is as clear as mud, where do the two wires in RBUS go to, the manual is saying you connect the room thermostat to these
hi Ian, the R Bus connector when new just had a jumper across it, i believe that this is for the Baxi usense remote unit.... which is what i should have purchased :)
i'm away for a few days now but will try what you suggested in the last message as soon as i get back.
many thanks again
Colin
According to the instructions you remove the link in the RBUS and connect the room thermostat, yours has wires going into it so it must be connected to some sort of room thermostat or ambient sensor, this si where the hive should be connected to
