Baxi duo tec 24 or Glowworm ultracom 24cxi???
27 May 2008
Northamptonshire
hi,
i need help i am looking to replace my old myson apollo boiler with either one of the 2 boilers above.
can anyone recommend which one i should go for?
has anyone got any of the above and had any problem?
i am looking to get the boiler from Mr Central Heating because they are doing a good deal with rad valves and inhibitors etc. has anyone used them before?
any help would be appreciated.
Much of a muchness really, both mid range boilers, same warranty, similar Gianonni heat exchangers.
I personlly would fit the Glow Worm as I can offer a full 3 year warranty on them, whereas Baxi only give 2.
personally wouldn't fit either! would look at a Vaillant
but if you want them then i would go with the poxy batterton
Valliant are much more expensive.
you guys recommend Viessmann Vitodens?
looking to spend £600-£700 on the boiler.
For that sort of price I could supply an ATAG E22C.
THE best boiler on the market, in terms of quality and reliablity. Call them and ask for your nearest 'Select Dealer' ;)
do you understand what kind of hot water performance a 24kw combi will give you? You currently have a conventional system with cylinder I presume. Whats the reason for changing?
you get what you pay for!!!
viessmann have had a bit of bad pulicity on here do a search! although my mate fits them and hasn't had any problems yet :LOL:
no i have just been told that i require a 24kw 80,000btu boiler.
the house is a 2 up 2 down.
the reason for the change is that currently i have a really old boiler that is costing me too much to repair each time it breaks.
if you want to fill a bath in a sensible time, I would be looking at 30kw
i bought a 40kw duo tec last week for 790 plus vat.hot water is brilliant.Have a look at the 28 duo tec for the sort of money you want to pay.Or check out the main 30 eco, basically same boiler(different heat exchanger)but cheaper.
