Hi guys , I have a baxi instant 80e a plumber fixed a leak and water got into the pcb which is now dry . I have hot water working perfectly , when I switch on the the CH it heats up through the indicator lights and gets to the max and shuts off , the flow pipes heat up inside the boiler but not out if it eg rads and pipes out if boiler. The taps on flow and return and open and pressure is at 2 , the pump is working to
