Hi Guys,
I'm hoping one of you can help me I'm at my wits end.
I have had an issue with my baxi105e boiler for the last 2 months in that it periodically trips with error code "60 Pump fault or low pressure". Doing a PCB reset does not clear the error, the only way to reset is to turn the boiler to the off position and press down the rear pin on the diverter valve. I have had an heating engineer out multiple times and it's costing me a fortune yet the problem still persists. So far the Pump has been changed, sytem pressure is normal 1.5 bar. The PCB has been changed, He replaced both diaphragms in the diverter and also changed both the micro switches on the diverter. He has changed the central heating and DHW thermistors. System has been cleaned, flushed and treated in case of blockage. Yet still I'm getting the "60" error the boiler can run for an hour, a day , 2 days or even a week and then just fail. When it fails the pin on the rear diverter diaphragm is in the up position, the pump is still running (pump casing feels hotter than normal)and the rear pin will not press down, it's still pressurised even though boiler is showing error 60, if I turn the selector switch to power off, I can press down the pin on rear diaphragm and boiler works again. Please can someone advise me what the issue could be, as I don't want to be wasting money on unnecessary parts and engineer costs. It's obviously tricky problem. Thanks for any feedback
