BBA Reman
17 Apr 2007
Brought to my attention by an episode of Wheeler Dealers currently on QuestOD.
Mike Brewer took the ABS pump for a VW Corrado VR6 to them for repair.
Has anyone had parts serviced/repaired by BBA Reman?
Yep:
VW Polo 1975 throttle body, SPFI
VW Polo 1980 throttle body, SPFI
Nissan Micra K11 Throttle body (who hasn't had one of those)
Mitsubishi ABS module, can't remember how old it was but it was a SWB and black :whistle:
Ford Focus 07 Auto ECU, sent in by me but it was fine and the fault was elsewhere - and I still didn't find it so traded it on :eek:
A BMW bit on an old 3 series but can't recall what that was :confused:
An excellent firm and highly recommended - but of course there are others.
John :)
Never used them but heard plenty of good things about them on some car forums that I frequent.
Thanks Gents!
I've got their website bookmarked for future reference.
Don't follow my example, resist the temptation to buy stuff as mentioned above from breakers or whatever......stuff your money in the drain instead :eek::eek:
John :)
Certainly not brakes from the breakers yard.
BigRed for caliper seal kits, that is if the piston/bore isn't pitted/scored. Due to bite marks from vice grips on the piston, c/o of the previous owner, I had to get a new TRW brand rear caliper for one of the Bora TDIs we have.
I'm curious about BBA Reman for ABS pumps should one ever go faulty in the family fleet.
Hopefully they won't - always expensive!
On the Mitsubishi I did (Don't know what model it was but it was SUV style 4x4) I knew the wheel sensors were working as I connected them up to a borrowed oscilloscope .....each one was producing an equal signal so logic said it had to be the ABS module. Happily it was!
John :)
T5 Transporter ABS pumps do fail (usually electrically). They usually get sent back as beyond repair if you try that route. People are asking big money on Ebay for rusty old ones that I wouldn't touch with a barge pole! You can buy the electrical (ECU) section separately but it's still £500 ish from memory. They do need coding after fitting and if the vehicle has ESP (or probably anything except plain ASR) it will have a steering angle sensor which will also need re-calibrating. No big deal if you have access to diagnostics.
For anyone ever buying a VW ABS pump second hand, be careful to get exactly the right part number down to the last digit unless a VW dealer confirms that any difference is an updated part.
I used them for my Saab 9-5 ABS module, posted off and returned in 5 days with a lifetime warranty. Exellent service.
