Bell Box Advice - Flashguard vs Orisec ES-330 vs Pyronix Deltabell X vs Texecom Odyssey X-B
3 Sep 2019
I am looking for a bell box and cannot decide which make to go with.
I am looking for a bell box which has the following features:
  1. Twin piezo – rated at 115dB or higher.
  2. Bright white or blue comfort LEDs – visible in daytime.
  3. Xenon strobe – LED strobes are not very bright in comparison.
  4. Backlit.
The 4 bell box makes I have looked into so far are:
  1. Klaxon Flashguard XL Plus.
  2. Orisec ES-130 and ES-330.
  3. Pyronix Deltabell X Grade 3.
  4. Texecom Odyssey X-B Grade 3.
The drawbacks I have found with these bell boxes are:
    While the Flashguard XL Plus is twin piezo with a 118dB rating, has bright red comfort LEDs which are visible in daytime, and a bright Xenon strobe, the drawbacks with the Flashguard are that the bell box is not backlit and the comfort LEDs are red instead of white or blue. Also, I heard the Flashguard bell boxes are unreliable.
  1. Orisec ES-130 and ES-330
    While the ES-130 and ES-330 are twin piezo with a 115dB rating, have white comfort LEDs, and are backlit where the backlight (D‑Lux) can be set to flash with the LED strobe, the drawbacks with Orisec bell boxes are that they all use an LED strobe instead of Xenons. The comfort LEDs also dim when alternating, though not when only one is flashing. I spoke to Orisec Tech Support and they said this is down to the voltage regulator on the PCB.
  1. Pyronix Deltabell X Grade 3
    While the Deltabell X is twin piezo, has bright white comfort LEDs which are visible in daytime, and is backlit where the backlight (LightBox) flashes with the LED strobe. The drawbacks with the Deltabell X are that it is not very loud, only rated at 109dB, and the twin piezos also crackle when sounding. They all use an LED strobe instead of Xenons.
  1. Texecom Odyssey X-B Grade 3
    While the Odyssey X-B is twin piezo with a 115dB rating, has bright white comfort LEDs which are visible in daytime, has a bright Xenon strobe, and is backlit. The drawback with the Odyssey X-B is that the backlight cannot flash with the Xenon strobe, nor can it be disabled when the bell box is going off, which would increase the visibility of the Xenon strobe.
Is there a bell box I’ve overlooked that meets all of these requirements without the drawbacks?
If you had to choose, is the Odyssey X-B G3 actually louder than the Orisec ES-330 in real‑world use, despite both being rated at 115dB?
You are in the trade ?
Where you getting the flashguard from, Klaxon(Texecom haven’t made these for years)
Orisec is trade only.
As for dim in comparison to which bellbox and with what colour lens?
You can make the back lights flash on the odyssey X, but it’s an output to fire.
The odyssey requires wiring to a photo cell or output to make it come on when it’s dark.
The Orisec draws less power for the output in terms of volume.
Does use a built in photo cell.
You can adjust the light intensity program with Orisec panel or manually using tamper to set to one of 8 settings.
Biggest issue with Orisec is probably the plastic screws to look the lid.
Perfect fit screw driver and make sure the back plate isn’t over tightened as it bends and can make the plastic screw retainers awkward to operate.
I guess you would need to write down what you want from the bell and tick each one off your list.
And see which one meets the list better
If your trade then screen prints usually require minimum order of 30 or more, odyssey x branding packs are available and these are cheap and don’t take up much room as they are insert sheets, if back light being used you want something to light up.
Screen prints look better than inserts until the screen print fades.
