Bell Box Advice - Flashguard vs Orisec ES-330 vs Pyronix Deltabell X vs Texecom Odyssey X-B
deffo looks normal,
But on this device I can see the brightness you claim to be seeing.
But this is the correct operation.
This is what I was trying to explain.
When both LEDs flash, they are a little dim compared to when only 1 is flashing.
Orisec should fix this. If they do their caomfort LEDs will be brighter then the Odyssey X.
Fast forward the video to 8:20 and watch it from there onwards.
There is nothing wrong with it though??
I guess the question is should it be the same brightness or not by design, how much of it is down to how it’s being viewed I can test it to some degree in if it looks the same or not.
I wnet through the LEd issue when i was at Orisec and was sat in a room looking at several different bells with there leds on, they are clear and perfectly adequate to be seen in daylight. WRT to the tamper making it brighter that because effectively more current is being run through one LED.
