Best Boiler
12 May 2007
Looking to change my gas boiler, it would have been in for 22 yrs since house was built, it is a ward 2000. The pilot light goes out very easily when there is some wind so not ideal. House is a 4 bed detached of avg size, 11 radiators, i have a hot water tank and tank in the loft, don't want a combi boiler so happy to keep the tanks, what would be the best boiler to get, i read a worcester greenstar or valliant, i don't know the best bits / pitfalls of either.
Probably the case seals need replacing if the pilot light is going out.
That and a new thermocouple would probably help.
Otherwise nothing wrong keep it.
If replacing get rid of the header tank and go to a sealed system
then my preference would be an Atag. I would stick a combi in
and use it as a system boiler. 24kW will do it.
Ideal w2000 thats right, for some reason i thought it was ward 2000. I have a british gas contract, should these things like a case seal etc get changed by them?, they always say they can't get parts
If you have a contract that includes parts then, yes they should replace parts as required. If they say "part not available", contact Ideal for confirmation of availability. Not a bad boiler either.
There is a vent on the side of the house which comes from the boiler, whenever you get wind down the side of the house you do see the pilot light flicker. I have asked Ideal about spare parts, i don't want to change unless absolutely neccessary as it has been pretty trouble free. I will definitely stick to a similar set up if i change it out, ie leave the tank in the loft and have separate heating / water facility.
Going to change the boiler out to a 18 kw vaillant ecoTEC plus open vent boiler and keep the same set up, anyone see any downside to this boiler, firend did suggest doing away with 1 of the tanks and having the system pressurised, think i will leave as is, less pressure ( potential leaks) then.
