    Dismiss Notice
Best flooring over a wooden shed floor?
Discussion in 'In the Garden' started by Hillendale, 25 Jan 2021.
  1. Hillendale
    Hillendale
    25 Jan 2021
    2
    Thanks Received:
    Country:
    Hello, I have a new wooden shed. I would appreciate any recommendations on what is best to lay over the wooden floor to protect it? It has a concrete paver base and sits on a wooden riser. This is a question for the interior floor.
    I was going to lay rubber flooring but thought that this will likely just make it rot. Thanks!!
  2. Sponsored Links
  3. sxturbo
    sxturbo
    12 Jan 2014
    2,304
    Thanks Received:
    347
    Essex
    Country:
    Carpet be fine
  4. foxhole
    foxhole
    14 Mar 2006
    17,184
    Thanks Received:
    1,976
    Kent
    Country:
    Protect it from what ?
  5. Malakym
    Malakym
    31 Mar 2012
    52
    Thanks Received:
    3
    Country:
    I use scraps of carpet near the door, and sometimes a strip along the main walkway(s). Replace as and when you get another scrap from somewhere else.
    • Like Like x 1
  6. Djangobanjo
    Djangobanjo
    17 May 2012
    6,513
    Thanks Received:
    387
    Country:
    why would rubber make it rot?
    I was thinking of doing a shed/gym with rubber flooring ...
  7. Hillendale
    Hillendale
    25 Jan 2021
    2
    Thanks Received:
    Country:
    To protect from dirt, grease etc as bikes will be stored inside. I was worried rubber on top of wood would trap moisture and cause rot below... rubber over concrete is different. Thanks for suggestions for re carpet. Its pressure treated wood already so I will paint ot to seal then lay something over to protect wood
  8. Sponsored Links
Loading...
Share This Page
