Chaps,
There seems to be a number of methods to fix new Oak flooring over existing boards, I am hoping that someone can clarify what would be best in my circumstances.
Room size - 4m x 4m
New boards are Solid Oak, Oiled, 120mm x 18mm, lengths 400mm to 1500mm.( existing boards are 150mm wide ).
New boards are to laid over existing 1930's boards which are all sound.
Existing floor is suspended with 12" gap between bottom of boards and blinding concrete. All air bricks are clear and subfloor ventilation is good.
I intend to lay new boards in line with existing rather than at 90deg. due to prevailing light from main window
Should I secret nail, screw ( ELKA Tri-Lock ) or glue?
Should I use a vapour barrier or underlayment?
If glued using an underlayment do I glue boards to the underlayment as well as the tongue & groove?
HRH
Room size - 4m x 4m
HRH
