Best way to 1st fix a conservatory
5 Sep 2006
Lancashire
I've been asked to 1st fix a conservatory. Which of the following ways (if any) would you consider the best way to do it.
Conservatory needs 4 sockets, 1 on one wall, 3 on another after patio doors.
I was going to run radial circuit in 4mm 3core SWA(from front of house round outside to consrvatory(RCD'd at CU)) to the outside wall of 1st socket, 4mm t/e into back box, via conny block in outside box. Back then along the outside of conservatory under patio doors to outside 2nd socket (in 4mm swa). Enter 2nd sockets in 4mmt/e, then go to the other sockets on that wall either:
Via cavity - which is full tight with insulation now.
or
in capping horizontal to each socket (though theres a 30 degree bend in wall and was concerned about when the plasterers dryline the corner of the wall.
Which way is best, or would you do it another way
Audit the existing grd / flr ring and add socket to that if suitable.
Audit use requirements in conservatory and work off a 13 a f/ spur.
Run 2.5mm or 4mm radial internally from CU subject to load /audit of use (as above).
I absolutely hate external runs for internal work, it's labour intensive and with swa you have to break on a suitable j/b to drop back to TE which when external (as you suggest) is kin horrid.
why T+E though? just leave the inner core long and use conduit through the wall straight into the backbox.. no need for extra joints to complicate matters..
is there no scope to run in conduit in the floor? ( or is it finished already? typical of homeowners.. nice new conservatory then decide they want some sockets.. )
Is the inside rendered? Not brick?
I would take the 4mm SWA (or 2.5mm 20amp is you want) directly into the conservatory before they lay the final screen. Fix the swa to the concrete oversite and loop past the sockets.
Use 35mm boxes, and terminate the SWA into these using a brass bush, serrated washer and a galv coupler.
35mm boxes have the knockouts further back than a 25mm allowing for render over the SWA and glands. I tend to use CW glands and ditch the shroud.
Hello.
Maybe an idea to allow for an outside socket too ? ;)
Ed.
