    Dismiss Notice
Best way to build bricks infront of a brick wall
Discussion in 'Building' started by New2DIYing, 13 Dec 2013.
  1. New2DIYing
    New2DIYing
    9 Jun 2013
    51
    Thanks Received:
    Country:
    Hi guys
    I have a brick wall inside my house which I need to build some bricks in front of (as the wall is too far back for what I need). The bricks being set in front of the wall will bring the wall to where I want it.
    Now my question is what is the best way to ensure the bricks I lay stay attached the the original wall? Will I need to lay mortar down between the two walls? Will this do the job?
    As I do not want to be left with a new wall that can fall if pulled!
    Thanks.
  2. Sponsored Links
  3. Blagard
    Blagard
    9 Feb 2010
    1,560
    Thanks Received:
    275
    Leicestershire
    Country:
    If the wall is for decorative reasons then simply plug and screw fix some frame fixings to the existing wall
    frame_cramps
    Use standard spacing for brick ties, i.e. one every 900mm along in rows 450mm apart You don't need mortar in the gap between the brick leafs
    You can get them from any builder merchant and possibly DIY stores
  4. tony1851
    tony1851
    23 Feb 2012
    10,091
    Thanks Received:
    1,526
    Manchester
    Country:
    How high is your new brick wall going to be?
    Is it to be structural??
    How are you going to support it???
    Do you know what you are doing because I don't
  5. noseall
    noseall
    2 Feb 2006
    41,821
    Thanks Received:
    2,609
    Staffordshire
    Country:
    Me neither.
  6. New2DIYing
    New2DIYing
    9 Jun 2013
    51
    Thanks Received:
    Country:
    Not very high at all I would say about 100cm it is an internal wall that I need to extend for decorative purposes.
    Let me try and show a picture of what I mean this is a side view:
    [​IMG]
  7. paulc2
    paulc2
    13 Nov 2013
    93
    Thanks Received:
    6
    Cheshire
    Country:
    (Why) does it need to be a brick wall? Could it be something else, eg a bit of 4x2 and plasterboard?
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
