Hi all,
I have a problem on my Biasi GAIA savio 28s (manufactured in 1999).
Basically it stopped providing hot water out the taps when requested, the up shot is that I have to put the central heating on to get how water to flow from the taps.
I contacted a CORGI registered heating engineer, who took at look and said it was the diverter valve and a replacement part alone would cost (…….get ready) £387.00 plus VAT plus fitting! As well as 2 new flow switches (nothing wrong with them)
After I showing him the door,
I had a look at some of the pages on this forum and carried out the following work myself.
Stripped down the diverter valve, cleaned and reassembled (works fine mechanically)
Checked the 2 diaphragm/membranes (bit flappy but not torn or punctured)
Checked the DHW filter.
Examined the main PCB and found there was an area that had signs of overheating (underneath the small heatsink at the bottom left hand side of the board)
Basically I have these questions
Is there anything else I should check for this symptom?
If the diverter valve works mechanically could there be anything else wrong with it?
Is a small amount of blackening usual on a the PCB?
Should I just change the board?
If so I’m getting contradictory part numbers, the manual says BG1015 108 and the stockests list the part as BI1045133 formally (1045104)
Any help would be greatfully appreciated.
Have a good week
Have a good week
