Biasi Gas Combi Boiler
24 Oct 2011
Could anyone tell me the difference between a 24 HE and a 32HE combi boiler please?
24he is a 24kw boiler, the 32he is 32kw. both refer to the hot water ouput of the boiler. you will get a better hot water flow rate from the 32he, water pressure and pipework being satisfactory.
so for a 2 bed house it would be better to get a 32kw boiler?
It all depends on what hot water flow rate you need.
There is no point in a 32 kW boiler if the mains can only supply 8 litres per minute.
Also the minimum Ch power is higher and will make the boiler short cycle.
Tony
