Hello,
A few weeks ago I had a problem with my hot water supply on an Alpha Ocean 240 combi boiler. From past experience I knew that this was down to the pressure switch not switching and suspected the fan to be the culprit.
I removed the fan myself to clean it up a bit and discovered that it was damaged and in need of replacement. As a temporary measure, I reassembled it, put it back in the boiler, and tried my luck, nothing.
At this point I called a local boiler service company in and explained the situation over the phone before they arrived.
They turned up and confirmed that yes, I would need a new fan.
The following day the guy returned and installed my new fan - it spun up fine but didn't seem to be creating the necessary pressure to throw the switch. Taking the tubes off the fan end and blowing into the switch tripped the switch and the boiler fired fine - this confirmed that the switch was operating fine. At this stage i suggested that the wiring to the fan may be backwards and that the fan may be spinning in the wrong direction - the guy dismissed this as incorrect and continued faffing about for several hours. In the end, surprise! Reversing the wires solved the problem! In the meantime he'd also fitted a new thermocouple as a precaution.
I returned home that evening happy to find that the boiler was working fine as my wife was 8 months pregnant at the time and a bit distressed.
Within about an hour of being home though, the pilot light extinguished itself when i called for hot water. I phoned the place to inform them and they said they had fixed the problem that they were called out to fix and that to fix this would be a separate issue/call-out. The guy talked me through a couple of potential causes over the phone and I realized that the engineer had mounted the thermocouple far too high in the pilot light. Before moving it, I reignited the pilot light and called for hot water - pilot extinguished. I was able to recreate this several times over. I then moved the thermocouple down myself in line with the manufacturers recommend gapping. Problem solved and the boiler has worked flawlessly for several weeks now.
Sorry for the long explanation, but I received a bill for £600 today - including £220 for the fan (one I could get online for half that without any trade discount).
They also justified the time booked to the job by stating that I had the fan out and had reinstalled the wires incorrectly. This may be so, however the guy then had it out and in again and made the same mistake despite a wiring diagram pasted inside the back panel of the boiler! Not to mention the fact that they ultimately left me with a boiler that didn't work due to the guy being so incompetent that he couldn't install a thermocouple correctly!
Really unhappy with this treatment and I need a £600 bill like a hole in the head particularly with my wife now due next week!
Do you think I have grounds for a dispute here?
Thanks in advance for reading this lengthy rant, and any input you provide.
JKBDIY
JKBDIY
