(I only said the second quote.
So does apply to the already tinned copper cable frequently used nearly 60+ years ago?
Intresting question.So does apply to the already tinned copper cable frequently used nearly 60+ years ago?
Perhaps, but it's presumably cheaper not to tin it, as well? Tinned copper wire is obviously still very widely available, and I use it all the time in electronic applications (where it is usually soldered, and very rarely has any interaction with terminal screws). Do not things like standard telephone wiring cable still have tinned copper conductors (even though they are sometimes used with 'screwed joints')?And is that why tinned copper cable isn't available now?
I must say that I've never been sure about the intended purpose of the 'tinning', particularly for 'house wiring cables'.
Quite so. It presumably markedly increased the manufacturing complexity/cost, so there must have been a (perceived to be 'good') reason - but, as I said, I don't know what it was.I doubt they did it for fun - I wonder if there might have some sort of chemical interaction between bare copper and the insulation?
Sure (very slightly - it was/is exceptionally thin), but so what? Are you suggesting it was done because 'tin' (or whatever it was/is) was cheaper than copper? If so, I doubt the price reduction due to the tiny proportion of the 'tin' involved would have even made up for the additional cost of manufacturing.Presumably the tinned part contributed to the actual cross sectional area?
It seems that it was/is tin, that it was/is done either by dipping or electroplating, and that it's advantage (at higher cost) is corrosion resistance. I found this:... I wonder how they did it, was it actually tin - maybe electro-plated?
Oxidation Problems
If you’ve ever seen the Statue of Liberty, you’ve seen oxidized copper. In exceptionally humid climates, such as on the coastline, in swampy southern areas of the U.S., or in highly acidic soils, copper reacts to water, oxygen or sulfur in the environment and degrades into a semiconductor. In other words, the copper becomes far less efficient at moving electricity through itself. This problem is most often solved by a process called tinning.
Tinning Benefits
When you apply a thin coating of tin to bare copper wire, either by dipping the copper in molten metal or by using an electric current to bind the tin to the copper, you create what is known as tinned copper wire. Tinned copper wire is just as conductive as bare copper wire, but the thin layer of tin helps the wire resist corrosion. Tinned copper wire can last up to 10 times longer than its non-tinned counterpart, and because solder is composed primarily of tin, tinned wire is incredibly easy to solder. Tinned copper wire is particularly useful in industrial cranes, subways and marine projects where the tin coat makes the wire more resistant to water.
Cost Disadvantages
Despite the many benefits of tinned wire, it is not always the right wire for the job. Tinned copper wire is more expensive than its non-tinned counterpart and can cost as much as 30 percent more than basic, bare copper wire. In environments where acidic soil, high heat or high humidity are not concerns for a project, non-tinned copper wire works just as well.
You did. Some copying/pasting went a little awry there. My apologies - now corrected.(I only said the second quote.)
