I think this is the right place for this post as it's about piping components. If not, please forgive me.
I've incorporated a pair of washing machine valves/unions in my kitchen refit plumbing.
There won't be a washing machine connected to them for some months and even then the hot one may be unused as lots of washing machines these days seem to be cold-fill only.
These valves only have a small-bore but if you happen to turn one on by mistake you don't half get a torrent of water. So, for extra security, I thought blanking caps would be a good idea.
I looked in various Plumbers' Merchants but didn't find anything suitable so I thought I'd have to set to work on the lathe and turn a couple up from a suitable grade of brass or maybe nylon, using the fittings salvaged from an old pair of washing machine hoses as a model.
Then I thought I'd try filling a couple of nylon hose end fittings with hot-melt glue. It sounds like a bodge but the glue appears to have bonded to the nylon OK and the shape of the plug of hot-melt is right to retain it in the fitting body. So I'll try them out and report back.
I have wondered whether the hot water would be too hot for the hot-melt glue but I think the glue melting-point is sufficiently high.
Comments invited as long as you don't claim to be so perfect that you've never turned on such a valve by accident!
