Blanking second switch problem
The switch that he wants blanked was previously converted from 1way to 2way by using the conversion method. Therefore the remain switch is connected via a 3core cable with the yellow connected to the common terminal, if he disconnects the yellow all will be fine.
Nonsense.
At the other switch connect the red to common, and the blue to L1, and disconnect the yellow.
Am I seeing this wrong?
He has one switch position with a 2 and 3 core and another with the other end of the 3 core.
If the blanked position will be where there are two cables, he could leave it as it appears in the picture (except for grounding the yellow), then just make sure at the other switch position that the red goes to common and the blue to L1 and the yellow to earth.
