Perhaps I was too hasty - might have found the culprit. A VHS recorder that hasn't been used for a while as PVR is used now - that was in the circuit connected to TV and appears not to work anymore. The fuse is intact however.
Should have known better than to slander those poor rats!
Hi, it's just a 5 amp as expected for that sort of device. Perhaps it's just a coincidence and I thought it might have been the extension board that it is plugged into but that is fused and all the other things plugged in work OK. I haven't used it since I started using the PVR so it might have stopped working at any time.
So a faulty VCR blows a 30 amp fuse while its own five amp jobby survives? Well I won't say it's completely impossible but I don't believe it. You could open up the defunct VCR and look for signs of a massive burn-out that would lend some credence to the ides but I still think the fault lies elsewhere.
PS: Just a thought. Is there any chance that the old fuse had the wrong size wire in it?
It was an old ceramic type with asbestos in the middle and the screws holding the wire were both tight. It's a bit strange since 2.0 am has to be when the lowest load is likely to be experienced.
