    Dismiss Notice
Boiler below 0 Bars, how to correct? making strange noise.
Discussion in 'Plumbing and Central Heating' started by blackcloud, 5 Jun 2018.
  1. dilalio
    dilalio
    20 Mar 2009
    6,509
    Thanks Received:
    939
    Potters Bar
    Country:
    Yep! Blocked condensate will do that to it! How is your condensate drained? No air gap I presume?! Straight into a waste drain!
  2. Sponsored Links
  3. dilalio
    dilalio
    20 Mar 2009
    6,509
    Thanks Received:
    939
    Potters Bar
    Country:
    I have a “special” place in my heart for landlords :cautious:
  4. nameisme
    nameisme
    15 Nov 2017
    74
    Thanks Received:
    3
    Country:
    I know the last boiler had a air gap going in the wall to out the house and when they installed the new boiler they closed the air gap going to outside as whenever it rained rain would come in. They did however drill a hole and put a pipe going from the boiler and connected it to something in the bathroom, I am guessing connecting the boiler to the waste drain in the bathroom?
    Thing is, wont a blocked condensate happen again? how can I avoid it happening again? When it is serviced do they clear out any blocked or building up condensates?
  5. dilalio
    dilalio
    20 Mar 2009
    6,509
    Thanks Received:
    939
    Potters Bar
    Country:
    Look in the manual and see the section about condensate connections - it provides all you need to know about how it should have been done.
    An air gap is not a hole around the pipe, through a wall... it’s a gap between the Condensate pipe and the drain into which it runs... like a washing machine upstand.
    And yes, it could happen again... should be checked at service intervals - make sure this is done from now on and perhaps complain that it appears not to have been!
  6. nameisme
    nameisme
    15 Nov 2017
    74
    Thanks Received:
    3
    Country:
    Thanks, how oftern should a service be done? can a service notice that condensate is building up and prevent this happening again? It was installed 1 year ago and the landlord has not had it serviced since installed.
  7. Sponsored Links
  8. dilalio
    dilalio
    20 Mar 2009
    6,509
    Thanks Received:
    939
    Potters Bar
    Country:
    Landlord Gas Safety Certificate must be issued annually... service from us would include checking the condensate trap and cleaning out if necessary. Remind your Landlord that this is due.
  9. Combicert
    Combicert
    29 May 2018
    109
    Thanks Received:
    20
    Country:
    Went to a landlord cert last week and they hadnt had anything done, from what i could make out... for 6 years, since the last tenant moved in! How do they sleep at night??
    Before i was GSR i would lose sleep if the safety cert was a week late
    Tight as a ducks arse some landlords...
    • Like Like x 1
  10. vulcancontinental
    vulcancontinental
    26 Jun 2010
    10,074
    Thanks Received:
    3,850
    Bedfordshire
    Country:
    What model? Did the engineer clean grey stuff from the trap?
  11. durhamplumber
    durhamplumber
    23 May 2010
    10,615
    Thanks Received:
    416
    Durham
    Country:
    Plus one for that comment!
  12. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
