Going to start a refurb (DIY)which will be a HMO (house of multiple occupation). Plan is 6 rooms all with ensuites (1in loft, 3 on first floor, 2 on gnd floor). Was thinking of the following design for DHW. 170Ltr megaflo serving the top 2 floors and a gravity system feeding the Gnd floor and communal kitchen.
First question is, will all boilers support the controls needed (or can I get an independant box) as I assume I will need a mid postion valve serving the 2 cylinders (located next to each other on the Gnd floor). Obviously both have the potential to call for heat simultaneously and independently of each other which can be achieved with the 3 port valve but it needs the ability to be able to be triggered by more than 1 source with the valve diverting the water to the "correct cylinder".
Next one is on pipe size for DHW. Is there any advantage on running 28mm pipe from the cold water storage tank to the standard cylinder? The cylinder only has 22mm tapping for DHW take off. Also is it worth coming from the 22mm DHW draw off and converting immediately to 28mm to the first bathroom then continue in 22mm for the next (better flow perhaps). In respect to the 28mm from the cold water storage I assume I will be at an advantage as I can take a feed from the cold water storage for balanced cold water for the shower valves or would I be better to run a separate pipe from the cold water storage.
I appreciate that there may be some loss of performance (mulitple showers at once) but hopefully my design is ok and will accomadate as best I can within the budget I have, although as always more than willing to listen to advice from the experts.
Thanks a lot
PS just as I posted thought that a zoned system for CH is more or less what I am asking for but on the DHW side (or am I barking up the wrong tree)
Thanks a lot
