Greetings
I've been having problems with this sander.
New-- out of the box, the sanding pad brake works fine-- switch on, pad doesnt rotate until in contact with the work.
After about 10 mins use-- the sanding brake no longer works. Power on, and it spins/rotates like a banshee. Thereafter, the brake occasionally works, but mostly doesnt.
I've now had 3 [replaced direct by Bosch] that do exactly the same thing. I asked them to test the third one before it was sent, but they didnt, and it does the same.
My Swiss made Bosch 280 delta sander is solid. all 3 defective GEX sanders have been made in Malaysia-- do they make them anywhere else?
Anyone got a GEX125-- does your sanding pad brake work?
Any advice comments much appreciated.
Thanks!
Thanks!
