    Dismiss Notice
Braun Electric Toothbrush
Discussion in 'Electrics UK' started by hansi, 16 May 2015.
Thread Status:
Not open for further replies.
  1. hansi
    hansi
    20 Aug 2003
    90
    Thanks Received:
    Cardiff
    Country:
    The moulded two pin plug attached to my toothbrush is failing as I have to jiggle the wire to get the charging light to work. is it safe to cut off the plug separate the wires and then attach a normal two pin plug on to it?
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,383
    Londonderry
    Country:
    Yes with same plug type.
  4. hansi
    hansi
    20 Aug 2003
    90
    Thanks Received:
    Cardiff
    Country:
    It will be replaced by a normal two pin plug obviously not a moulded one
  5. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,919
    Thanks Received:
    2,043
    Oxfordshire
    Country:
  6. RI1982
    RI1982
    9 Mar 2015
    6
    Thanks Received:
    Country:
    Could you fit a normal three pin plug in one of these providing you use a 1 amp fuse? I think that might be safer than using the adaptors which seem a bit clumsy so me.
  7. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,919
    Thanks Received:
    2,043
    Oxfordshire
    Country:
    But how will he plug that in his bathroom? :rolleyes:
  8. hansi
    hansi
    20 Aug 2003
    90
    Thanks Received:
    Cardiff
    Country:
    You beat me to it. Of course, I charge it from a shaver socket so i can't use a three pin plug.
  9. JBR
    JBR
    9 Jan 2007
    8,917
    Thanks Received:
    390
    Cheshire
    Country:
    My wife charges hers using a 3-pin socket (it has an unearthed 3-pin plug). I can't see a problem of the OP doing the same.
  10. Sponsored Links
  11. hansi
    hansi
    20 Aug 2003
    90
    Thanks Received:
    Cardiff
    Country:
    Except that I charge it in a shaver socket in the bathroom.
  12. ban-all-sheds
    ban-all-sheds
    27 Aug 2003
    69,783
    Thanks Received:
    2,857
    London
    Country:
    In which case don't necessarily follow PBoD's advice.
    You keep saying "normal two pin plug", but there is no such thing. Or rather there are different types of such things.
    If you're using a shaver socket for it then you need to put a BS 4573 / IEC 60884-1 shaver plug on it, not a CEE 7/16 Europlug. They are not the same.
    Also, does your shaver socket have a toothbrush symbol on it
    [​IMG]
    or is it lacking one, or labelled "shavers only"?
  13. JBR
    JBR
    9 Jan 2007
    8,917
    Thanks Received:
    390
    Cheshire
    Country:
    I know. You said so.
    I'm just saying that you (or your wife) could charge it using a normal socket - not in the bathroom, that would be illegal, but anywhere else.
  14. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,919
    Thanks Received:
    2,043
    Oxfordshire
    Country:
    He could use another socket, elsewhere, but he does not want to.
    He wants to use the existing one that is prefectly adequate for charging the toothbrush, in the room that the toothbrush is being used.
    Why does everybody want to make a simple thing so bloomin' complicated?
  15. hansi
    hansi
    20 Aug 2003
    90
    Thanks Received:
    Cardiff
    Country:
    Thank you. No, my bathroom socket does not have a toothbrush sign on it. Why would that make a difference. And when I said "a normal 2 pin plug", I meant the two pin plugs that we used to use and wihich are attached to shavers. I think I'll just buy a new toothbrush! :(
  16. Taylortwocities
    Taylortwocities
    28 Jul 2006
    19,919
    Thanks Received:
    2,043
    Oxfordshire
    Country:
    Yes, that's what you need.
    Go and do it and save yourself some money.
  17. DetlefSchmitz
    DetlefSchmitz
    17 Aug 2010
    2,224
    Thanks Received:
    292
    Country:
    Apparently the shaver sign meant you must only plug a shaver in, and not something else with the right plug and the same current draw. When they changed it to a picture of a toothbrush it all became ok.
Loading...
Thread Status:
Share This Page
