When adding a couple of new rads to my central heating system I encountered steady drips of water from the existing pipes where I had cut them to connect up.
I took advice from a friend that you can stop this by blocking the pipe with bread which holds back the water whilst you solder but the dissolves shortly after.
Now only half of my rads get hot, presumably because the flow pipe is blocked with bread.
What can I do?
What can I do?
