Morning,
A plumber has drilled through one of my bricks to feed through a copper blow out pipe from an unvented cylinder.
However when drilling through it has taken a good chunk of the front of the brick off to a depth of 0.5 -1 inch. I have kept the pieces of brick.
Basically can anyone recommend a product to stick this back on with? No More Nails, Gorilla adhesive etc...?
Also where the copper pipe comes through the brick - should I seal round the gap? I do have some mortar mix in the shed if should use this?
Thanks in advance for your help.
