Thanks, I take your point, they have said that they will be rendering to the bottom but obviously not directly over the DPC, this is the bit I'm slightly unsure about, its a difficult situation as it took along time to find a builder I was happy with based on seeing previous work and one that fell into a reasonable budget (others were quoting around £60k+ for the extension and bit of internal renovations) and at this stage it would be difficult to suddenly pull the plug and start again if its not quite that desperate yet but some of the comments are a bit worrying but they have assured me that have lot of experience and things will be fine.
I understand this is the type of thing they are planning, using an external bellcast bead however the bricks will also be rendered but they will be recessed by 15mm from the rest of the wall, DPC and bead will divide, not sure how acceptable that sounds though.
