You won't cut trim with a stanley knife. A diamond blade will make short work of it though.
get a dremel, just for this to try and right a wronged job
I have a dremel and it works well for removing bath sealing strips, but for tile trims, using a slitting blade in a dremel doesn't have the torque necessary to cut the trim at the back. The blade will cut fine at the surface, but at the depth necessary to cut through the whole strip.... it just won't work.get a dremel, just for this to try and right a wronged jobYou won't cut trim with a stanley knife. A diamond blade will make short work of it though.
Balls - the plastic would firm up the instant you move the heat away. I expect better of you Joe... or is this part of one of your games?If you heat the plastic up you can cut it with a butter knife - never mind a Stanley Knife.
You actually don't have a clue do you? You're just guessing.As far as the original problem goes I'd have tried heating the old edging strip with a heat gun until it became malleable so you can bend it up - then use a Stanley Knife to cut it off flush.
Try it. You heat it, bend it and cut it. It doesn't have time to cool.
Absolutely no it isn't - you're wholley entitled to say what you want on here. What I have a problem with is people that recommend a course of action and don't have a clue what they're talking about.Oh and if I want to suggest good ideas to the folks in the tiling forum then I will. It's not your forum is it?
It's not the speed Jef, it's the torque. The fact that you need to cut the back of the trim means that you'd need to have at least 8mm of the slitting blade sunk in material that it's cutting and they just won't do it.depends which dremel you have mr Gc mine will go up to 33000 rpm and would cut through with no worries at all
The poster might not have one.![]()
Or maybe he means a brain. He obviously doesn't have one so may think it's quite common.The poster might not have one.![]()
what a dremel? an angle grinder? or a hairdryer and a knife?
