Broken attachment when taking off radiator
20 Aug 2012
Dundee
Hi, Me and the hubby were unscrewing the nut the holds the thermostatic valve to the radiator and we think we have bent/broken it. It is the brass nut the sits between the copper pipe and the rest of the valve bit. It is sitting slanted and allowing water to drip out slowly. We can't get the nut off though. We are not sure how to go about fixing it, because it is not straight it is not making a perfect connection when screwed in. Any help would be greatly appreciated!!!
Sounds like you've cross-threaded it.
Two options:
1) undo it and hope it will go back on properly
2) replace it by cutting the copper, putting in a short piece of copper to replace the copper you cut off and fit a new valve.
Two options:
As always, a picture is worth a thousand words.
Erm let me figure out how to post a pic and I will show you guys.
It is the nut at the bottom that connects to the copper pipe. The whole valve is now sitting slanted.
It's the whole thing that's cock-eyed.
If you've crimped the olive onto the pipe like that I think a hacksaw might be needed!
It is an odd looking TRV.
Here is the side view. I think we have either bent the bent when try to unscrew the nut that connects to the radiator or as previously mentioned we have moved it off the thread. Also we have put a cap on the end (left) as we couldn't seem to shut the valve off 100%.
Any any case will we have to cut the pipe? Can we do that ourselves (ie what does it involve) or will we need a plumber? Thanks!
This damage is easily done, when the valve isn't held upright when it is disconnected from the radiator.
I'm afraid that kinked bit will give trouble, so its time to cut the pipe back and introduce a new short length of copper. You can use a compression fitting (not the neatest) but it saves soldering which needs the pipe to be completely dry.
The system will need to be drained down for this.
John :)
Thanks John. The nut was on so tight that when my hubby went to unscrew it he applied a bit too much uneven force. We will know for next time :)
