Build A NZ -UK Power Lead
Where I am at the moment is that I have got a lead with NZ plug on one end and IEC C13 on the other. I decided on that because I already have a long C13/ C14 lead so that will connect to the mains, then I have a C14 lead that I can wire into a 6 way trailing socket.
That way, I can have a long lead or a shorter one.
I ordered a 6 way block from Amazon that said it was surge protected but when it arrived it wasn't. But it is fuse protected. Ideally, I'd like surge protection, but I can't find a surge protected trailing socket with fuse protection. I will put a 5A fuse in the trailing socket so the 0.75 flexes won't get overloaded. Even though the industry fit appliance plugs with 13A fuses where the flex is 0.75.
So I may compromise and keep the 6 way trailing socket I already have.
Edited for clarity.
.... I ordered a 6 way block from Amazon that said it was surge protected but when it arrived it wasn't.
Does that really concern you? What sort of things is it going to be used to supply (although, IMHO,, even that doesn't matter much!!).
Kind Regards, John
Possibly a laptop.
All I can say is that that would not worry me.
However, views abut such things obviously differ - and change - [ some of those who, not so long ago, asserted that surge protection was 'snake oil' are now promoting it :-) ]
Kind Regards,m John
Just wanted to drag this out of retirement to belatedly thank people for their help with my extension leads.
I made up two for NZ, a 4 way and a 6 way strip, both without surge but having a neon, an on/ off switch and a fuse holder.
I did fit a 5A fuse to limit the current as all leads are 0.75.
I've used it hundreds of times, not just for NZ, but for all the weekends we have gone away. Travel Inns and Premierlodges often don't have sockets by the bedhead (???) or they are on the wrong side, so I bring a kettle lead, the 5m extension and a "strip", then I am prepared for any eventuality.
The beauty of this system is that you can go to whatever country you like and just get a kettle lead with that type plug and swap it out.
No messing around with fiddly adaptors and no rewiring plugs.
I'm currently in Lille using it with a Unischuko lead
I once bought a few AU plugs to make some extension leads for 6 gang BS trailing sockets for my daughter and gave her strict instructions to change all her fuses to 10A fuses (I gave her a few packs of them later) , a few months later I asked her if she had fittend them "No need Dad, they all still work with the 13A ones left in!" . Well I tried,
No it will not make much difference, if any, in the real world and the main thing is she did follow my advice of not actually have many amps running at the same time.
I must admit of all of the plugs and sockets I have ever used then I do favour the good old UK ones (I might be biased though!) ;)
Biased is one word for it. Wrong is another.
Well when I said Biased that was my way of agreeing I might not be right therefore I might be wrong. I do think I am right or thereabouts (with the ones I have tried on holidays etc, therefore not exhaustive) but I would be open to a rethink too if someone wants to try, fair fair.
Truth is that it is merely my opinion thus far.
One thing I do like about our UK version of plugs is the abillity to make The E conductor too long therefore last to disengage on catostrophic pull out, a nice little edge on things if people bother to do it.
Quite so.
I do think I am right or thereabouts (with the ones I have tried on holidays etc, therefore not exhaustive) but I would be open to a rethink too if someone wants to try, fair fair. ... truth is that it is merely my opinion thus far.
In terms of the plugs, per se, I feel similarly - that, of the alternatives I've seen, I'm inclined to favour the BS1363 plugs.
However, that's only part of the story. In terms of the 'big picture', I think it's probably true to say that overheating of (and thermal damage to) both BS1363 plugs and BS1363 sockets is very commonly due to poor connections to the fuse. However, that's not so much a matter of the plug design as of the (essentially restricted to UK and a few 'anglophile places) need for fused plugs, which is an implicit part of the design concept of UK electrical installations - but to change to installation designs which did not require fused plugs would be essentially 'unthinkable'!
That's quite often said, but I suspect that it would be very rare for the order of 'violent disconnection' of conductors to make any real difference, wouldn't it?
Kind Regards, John
Having handled a lot of shuko fittings I'd happily transfer over to those in the blink of snapping a heart beat and get away from the horrible system UK has standardised on.
Just my opinion and one I know is not universally shared so no need to bite my head off :D
Having handled a lot of shuko fittings I'd happily transfer over to those in the blink of snapping a heart beat and get away from the horrible system UK has standardised on. ... Just my opinion and one I know is not universally shared so no need to bite my head off :D
We will all have personal opinions, which will inevitably differ, but that's never a reason for biting any heads off!
Youyr opinion about this may be true/valid but, as I said, to move the UK to a system which did not have fused plugs would essentially be 'unthinkable'.
Yes John it would be quite rare or at least not common but I feel that the possible advantage gain by E disconnecting last (or actually remaining connected once one or both lives have disconnected ) could sometimes be a worthwhile thing - an improvement on not doing such a relatively easy thing.
Of course it just makes one a little happier even though it not a pile of bodies in the street sort of thing.
