Building Porch - hopefully rendered single skin
15 Apr 2009
Worcestershire
Is it possible to build a single skin porch out of breeze block only? Obviously up to DPM it will be engineering bricks. The front of the house (up to 1st floor height) is rendered anyway and I need to maximise my internal space of the porch.
At the same time I wish to avoid any internal damp issues. Should I use any particular breeze block e.g. thermalite, celotex etc? Can I render straight to this? Should I render both sides? Sounds crazy but Ive heard of people doing this! Got to be an easier way.
How best should I clad and skim the interior?
Any help much appreciated.
Forgot to add I wish to house a dryer (externally vented) and dishwasher or a washing machine and dryer (not decided on the combo as it all depends on the internal space I end up with hence the importance of single skin) if that affects decisions over internal coverings etc.
Well observed. You can blame baby for the need for extra space. I blame him for having to sell my S3 anyway...
Back to the task in hand - thoughts anyone?
Yes you can build a porch from single skin breeze block then render.
It will always have condensation related damp issues though, unless you insulate. Any amount will be better than nowt. You could fix 37mm insulated plasterboards to the internal walls but this may not be enough to stave off condensation, particularly during very cold temperatures.
A mechanical extractor would be a boon also.
Cheers Noseall. By mechanical extractor I take it you mean a dehumidifier? Are there 'slim' concrete blocks I could use to create a cavity wall that a) wouldn't decrease significantly the internal dimensions whilst b) avoiding any condensation/damp related issues?
