What order is a brick and block wall built using full fill insulation ?
Is it a case of build the block work up to the height of the insulation batt, then fit insulation and then build the brick skin, or do you fit the insulation after the brick skin has gone in ?
I can see how rigid insulation is done, but not how full fill works.
