Bypass valve (manual) problems....?
do you mean boiler would go to lockout on overheat if all trvs shut down and the bypass valve was stuck closed? providing thr boiler had an overheat cut out/stat.
and that the rads will not get as hot as they should/did if the valve was fully open?
what would happen if a manual (gate vale type) bypass was fully closed.... or fully open ... would it be dangerous
What are the symptoms of the plumbing and/or central heating problem that you wish help in solving?
