I have a conventional (Loft Feed Tank and S Plan) system with a Vaillant 438 Boiler. I'm struggling to get flow to the final radiator. Most of the others have the adjustment valve virtually screwed down. The (new) boiler does not fire that often and probably only fires for 30 seconds.
I'm thinking that the last (new) radiator has not got good flow.
However, I've tried this evening to see if the ABV is adjusted correctly. I thought I was onto something when I found that its pipes were hot. It was set at 0.4 Bar. My calculations suggested it should be set to 0.38 (the Vaillant requires 27.2 l/min). I've tried it at many settings and now have it above 0.5 (0.6? but unmarked). It still flowing at the same temperature as the heating.
Do you think its a combination of all the lockshields being wound mostly down and a faulty final radiator?
Any thoughts on how I check the flow through the final radiator?
By the way. The system is mostly new but just some of the original pipes. This final (vertical) radiator replaced a large old panel that used to be the warmest on the old system. The pipes have been power flushed but nothing much was found in the system. It has a Fernox filter.
