C+K Securitech alarm tamper help (pics included)
21 Aug 2012
Essex
Hi all my first time on this forum do first of all a big hello!
Second my problem is my house alarm, the panic button in my bedroom was pressed by accident some months ago. My missus and I both forgot the code to stop the alarm and I panicked (lol no pun intended) and ripped the battery out thinking that might stop it we had the key to reset the pa button but the alarm kept going. We did remember the code after 15 mins of panic. Since then the tamper light is flashing on the keypad I have since reconnected the battery. I tried the reset as its written on the keypad but the tamper light stays on. Can anyone help please?
Many thanks.
Check to panel lid is on correctly and the battery correctly connected. Or open the panel lid and hold down the tamper switch or tape it down this will prove if the lid was not on correctly. Then do the reset as on lid. If it clears the tamper will re occur when released again to secure the lid. And check pa is reset. Should be ok no real drama. Keep us updated.
Hi
So you mean attach the battery panel cover as I forgot to do this and I noticed there is an attachment for a wire that hangs out of the box? I'll do this in the morning as I do t want to wake the neighbours.
Thanks for the reply.
Bluestifford";p="2489874 said:
Hi
So you mean attach the battery panel cover as I forgot to do this and I noticed there is an attachment for a wire that hangs out of the box? /quote]
There is your tamper fault.
From the previous answer, I don't know how the PA is supposed to be having any effect?
