C Size batteries what voltage are they
BAS The one I have is 'Digiteck' model 615, 6v not a sticker, but hot stamped on the unit.
The alarm is designed to run for, presumably, quite a long time on batteries, so the current draw won't be much.
500mA SHOULD be enough, but if you can, get one that will supply more (say up to 2 amps) - then you know it will work.
