Yes i will get an electrician, it is a charity event i have been asked to look at POwer.
The problem is that you don't know enough, and charitable status does not include exemption from the laws of physics.
When i find an electrician that offers his service for free to support the charity i will. At this point i am asking for advice on the cable not how i connect it.
It's not as simple as that - connecting a cable, of any type or size, may not be safe.
I assume the consumer unit is earthed, and i assume the cable i get will have an earth. The equipment will be earthed.
Exporting earths from one equipotential zone to another is not a good idea.
Ideally looking to make a 100M extension cable protected from the consumer unit running 100M that can carry upto 2KW.
What do you think you mean by "extension cable"?
Looks like 6mm cable is required and best to use armoured cable .
1) 100m of 6mm² SWA is going to set you back £250 - £300.
2) SWA cannot be casually connected to a CU - see this:
//www.diynot.com/wiki/electrics:swa-gland. A typical plastic domestic CU will probably have neither the space nor the strength to accommodate SWA glanded into it.
3) What would you do with it at the marquee end?
And yes a generator is looking a cheaper option.
There are more important factors than price, charity or no.
You are so far into your zone of unknown unknowns that you cannot begin to spec this job or make design decisions.
Whether you have to pay or not, you have to get an electrician, there simply is no other option. If you can't find one who will do the work for what you can afford to pay then you cannot host the event, it really is that black and white. Can you say "Public Liability Insurance", for example? Have you looked into local authority licensing requirements?
As well as not being exempt from the laws of physics, charities are not exempt from the laws of the land.
[EDIT]Wiki link corrected[/EDIT]
