Good morning all.
I want to add some extra sockets in a 1930s two-bed semi that I'm renovating down in Bideford and had a query regarding cable size.
At the moment, the consumer unit connects to two mains circuits - one labelled "downstairs sockets" and the other "upstairs sockets". These both are radial circuits (with some spurs) using 4mm cable, protected with 32A breakers.
However, the "upstairs" circuit only powers one socket in the main bedroom and two in the lounge downstairs!
The downstairs circuit powers one socket in the main bedroom, one in the second bedroom, one on the landing, one in the dining room and three in the kitchen, plus spurs for washing machine, fridge and freezer. (9 doubles in total)
My idea is to change the "upstairs" circuit so it supplies the two bedrooms, lounge and dining room, adding in a couple of extra sockets, and use the "downstairs" circuit to supply the kitchen.
From my limited research it seems it's more normal to use 2.5mm cable for mains circuits. I don't want to remove all of the old cabling as a lot is chased into walls. Obviously, I don't want to mix sizes but is there any reason not to use 4mm other than it being more expensive?
Also, is 32A too big for the circuit breaker on a radial mains circuit?
There are two lighting circuits on 6A MCBs so that seems normal. However, the boiler is running off a single cable with a 20A MCB. Is this too big?
The only other circuit is for the cooker - with another 32A MCB.
All advice welcome. Many thanks.
